My Dyno Graph from sunday....
#31
Drive-by provocation guy
"Ahmet: 270hp, 300 ft/lbs (k26/6, 18+ psi, guru chips)"
Wow, are those art the wheels??? I would have expected more roll off with the 26/6.
#32
Jimbo, I agree... This is what makes it confusing...
toddk911, I've never claimed 270hp... The printed max hp is 259 while the graph shows something below that.
Ahmet
Ahmet
#34
We just found out the graphs were shifted because the dyno owner didn't know how to set up the software properly, so he is redoing the graphs and sending them to us.
#35
Ian, as I've posted in the other thread:
The quoted #s are correct, the chart is very accurate but not very precise. If you were to shift the plotting of the data upwards (by the appropriate amount, the same value across the chart) it would be spot on. I should have correct charts printed at some point, perhaps early next week. I will have the data available in electronic format also. This was caused by a software glitch that resulted from the update to new software that's more precise. As a note, correction and smoothing factors were 0, and the numbers are actual.
Ahmet
Ahmet
#36
toddk911, I'll add this as I've posted under another thread since my car's in discussion:
"Also, if this has not been adequately mentioned earlier, though I don't think my chips are perfect for this particular car, on the road they're giving MUCH better mixture than on the dyno. Danno has informed me that my chips are mapped for 15psi, which can change some things too. Also apparently the car's running stronger than any other non S he's seen (does this let me mention my perfect compression/leak down again?). Blah. I'm happy overall I think..."
Ahmet
Ahmet
