My Dyno Graph from sunday....
All three charts have the same alighnment problems.
As stated by randy it is being looked into at the source (owner of the dyno)...
Once more is known we will get back to you, perhaps with new dyno graphs, or maybe just an explination.
I hope BOTH the line and the numerical measurements are off. That car should be making at least 380 to the wheels with proper tuning. With enough boost, that car will make over 400 to the ground.
Originally posted by Sam Lin
Wheel diameter and gearing are irrelevant on the dyno.
Sam
Sam
Sam
Sam
Originally posted by billgot
What am I missing here? Looks like 280-290 in TQ and HP how does this dyno work.Hell of a A/F ratio. ignition might need some work.
Originally posted by Magown
Ahmet's chart is just as screwed up as theirs. Are Streckfu and I the only ones who see's this?
I feel the peak numbers that are printed on the three dyno sheets are close to what the cars should be putting down.
Mine 330HP, 320 Ft/lbs (Stage II, hot day, poor IC cooling and 17psi)
Randy: 300hp, 300 ft/lbs (Stage II, 15.5psi, needs more tuning)
Ahmet: 270hp, 300 ft/lbs (k26/6, 18+ psi, guru chips)
All the charts reflect much lower numbers, but those peak numbers look to be close to what they should be given the conditions.....
I'm lead to believe the peak #s are the corrected values, while the charts show the actual recorded #s. I am looking into it still, and will have an update by mid wednesday at the latest.
Ahmet
Ahmet
Also, we have driven the cars too.... I am no expert, but my butt dyno tells me I am making in the neighborhood of 300/300 at the wheels... certainly not what the graph reads..
If you look at the very top right hand corner it states. Smoothing set to 0. Thats why you have edge's on the graph. If it was set to 5 you wouldn't see any edge's. Using the edge's helps in tuning. For instance. If you see edge's on the build up of TQ you would know that your not getting enough fuel. It could also help spot detonation before it's to late. The dyno was built to be a diagnostic tool before a meter for hp.
Usually when the dyno is SAE or STD corrected the graph would show The corrected numbers as well.
