Wideband datalogger setup
Do any of you guys know where and which wires need to be spliced into the ecu for my datalogger?
The M-400/M-500 features a built-in 6 input(2 speed, 4 analog) data logger. The 2 speed inputs can be connected to any signal which gives a pulse (Freq Range: 0Hz-10KHz) and the 4 analog inputs can be connected to any signal which gives a voltage between 0-5V. Analog voltages between 5V-25V will be capped at 5V and will not damage the data logger. Here are a few examples of signals that can be logged by the M-400/M-500.
Vehicle Speed (MPH/Kmh) Ignition Pulse (RPM) Shaft Speed Sensors Knock Sensor
Throttle Position (TPS) MAP Mass Air Flow Sensor Brake Signal
Air Intake Temp (AIT) Engine Coolant Temp (ECT) Exhaust Gas Temp (EGT) PLX Wideband Air/Fuel Ratio
PLX G Sensor (Single Axis) PLX G Sensor (Dual Axis)
Blue - Speed Signal Red - Analog Signal
