Test pipe isntall questions...
Shouldn't the head of the test pipe connect to a flange (I think that's what it's called, I'm talking about the 3 bolt connector on the head) that is coming down from the turbo downpipe? My system has no flange, it's been welded on..
As you can see, the new cat has been welded on by the PO..
If you look closely, you can see that the cat has been welded on to the pipe coming from the turbo downpipe. Do I need to order a special "flange" or just take it to a shop and get the head of the pipe welded on?
![](http://forums.rennlist.com/upload/under_car_12.jpg)
![](http://forums.rennlist.com/upload/under_car_10.jpg)
![](http://forums.rennlist.com/upload/under_car_8.jpg)
Drive-by provocation guy
A shop won't touch your exhaust unless they are putting a cat on after they are done. You would have to find someone wiling to do it "on the side"
I think you are not looking at it quite right. The flange connecting the cat pipe to the downpipe is most probably fine, you just need to look farther forward and up (towards the turbo). The downpipe isn't very long. Go check it out again.
Yeah, unlike other cars with a flange before and after the catalytic, the 951 has the cat welded to the middle section of exhaust. The flanges are at the end of the turbo downpipe and the beginning of the cat-back section. When people say "testpipe" here, meaning a catalytic bypass, they are really referring to a completely new middle-exhaust section that has no catalytic converter installed. So you can get something like the Burshc "testpipe" for $220 which is a complete 4-foot long section that bolts up in between the turbo downpipe and the catback.
I've still got cat-bypass pipe from my Supra if anyone wants one. It's an 18" section of 2.75" pipe with a 2-bolt flange on each end. Installing it was simple, undo 4-bolts, drop catalytic converter, bolt in bypass pipe. If only Hans and Frans engineers actually worked on cars, it would've been a lot easier on all of us.
"So why can't you just cut the cat out, and weld in an exhaust pipe of the same length and diameter as the existing pipe?"
Not a problem and a lot of people actually do it that way. Just that not everyone has a welding-torch in theri garage. It's also illegal for automotive shops to do that kind of a procedure as well and they can lose their license and face stiff fines. At my last smog-check a couple years ago, I had to go to an official State of California inspection station and they even pulled out a dental mirror and checked all around the welds to make sure I didn't weld in a bypass pipe. I've seen cops look under cars that have modified exhausts as well. I think the fine is around $1500 for removing a cat. So the really stealthy procedure would be to weld in a cat-bypass pipe internally and keep the entire outer housing. Or even better, get a testpipe and weld on the outer catalytic housing (that way the flow is uninterrupted on the inside).
Sounds like a project for the various wrenching societies that are popping up... "Ok class, today's topic is 'Getting Around Smog-Emissions Laws 101'"
Danno, cat removal is something i wanna do before i get my car up on the dyno, so it can be tuned that way. (does it make a difference?) I'm considering just gutting a cat and having mine as a spare. is it worth it to source a used test pipe instead?
~Eyal
~Eyal
a test pipe gives you better flow through the exhaust than a gutted cat. the sudden change in diameter can cause large boundry layers and turbulent flow, which can create some added back pressure (bad) that wouldn't be there with a straight pipe.
Call around to some of your local performance shops. You might find someone willing to do a side job for a good price. I got a full 3" exhaust done from a guy for 250$ labor, 100 parts.
