Anyone know or have Turbo S rotors for sale?
I am about the install the 993 calipers I have wich are the same as the S4 calipers..I will swap the crossover tube and bleeders and etc.....
Where can I get 951 S rotors..and should I get crss drilled or not..I have used crossdrilled and found no problems but on the reack some say they crack...let em know your oppinins..
Just as the turbo caliper came right off the 928S4, so did the rotor. I can't tell you if crossdrilled will make any difference, as I use the basic S4 rotor on my car. OEM Zimmermans have lasted 2+ years and a bunch of track days, and still are fine, have a set of another OE german make in the garage for when they go later this year.
I've not found them any cheaper than at Vertex - $89/rotor, and Hawk HP Plus pads for $89. Don't know if I'd buy used/rebuilt parts from them based on feedback here on Rennlist, but have had fine luck buying brake stuff.
I get my brake rotors from Sunset Porsche, stock 89' 944 Turbo rotors, prices fluctuate with Porsche, but you won't find OEM any cheaper.
If you plan on serious track use, avoid drilled rotors like the plague. Otherwise, it doesn't matter, you won't notice the difference.
Sam
Sam
Originally posted by Danno
Nope, the 964 uses a 298x28mm rotor, I think the same one as the stock 951. The TurboS and 928S4 uses a 322x32mm rotor and is the same one used on the 993RS/C4S/TT cars.
944 Turbo (220 bhp) uses 298mm front rotors and 299mm rear (944 S2 and 968 also)
944 Turbo S (250 bhp) uses 304mm front rotors and 299mm rear (944 S2 and 968 with M030 also)
Rear pads are the same, front pads are much larger on Turbo S brakes.
The 322mm rotors were never used on a stock 951, even if we can adapt it
Originally posted by Darius Juca
wow man !!! bythe look sof your rotors and pads you are haning fun!!
Here are my tires (Michelin Pilot Sport Cup) afer 1,5 track event
