[zt-2]WB02 Sensor in stock location?
I'm wondering if anyone has done this yet. The zt-2 has a simulated narrow band output so I'm thinking you could just intercept the signal going to the DME and replace it with the zt-2 signal. Anyone know if the sensor will screw right in to the stock location? Any issues on heat, etc?
You cannot use the stock location for wideband O2 sensors, being before the turbo the exhaust heat and pressure are both too high and destroy sensors, as well as making for inaccurate readings.
Sam
Sam
