Would you buy???
Due to lack of funds and as much as I don't want to, I am considering selling/parting out my baby, an 86 944 Turbo track car. Please read and give me your thoughts.
The car is loaded with everything needed for the track including 2 sets of wheels and meets all rules and requirements necessary to race, [see details below] but currently the motor is out and in parts due to a spun rod bearing.
I also have a trailer and a 1988 Ford Bronco 4x4 too (which was my tow vehicle) if someone wanted to do a complete package deal to go racing.
The car is still street legal but would need smog and since it was a "track only car" back in 2001 it's not been registered since then and I never listed it as a non-op so I believe there may be some fees associated with that if you wanted to use it as a street car.
I paid $11,000 out the door for the car back in 2000 in near concourse condition, [it had one other owner before me] I've since put nearly $25,000 more in parts. I say nearly because I'm too afraid to add up all the receipts which I still have, not to mention that's $25k wholesale, retail would be closer to $35-40k. The odometer reads approx. 115k miles. (I don’t recall exactly what it is off the top of my head at the moment.)
There are currently several similar complete cars [with the engine installed] listed here in the Rennlist Classified section with the average asking price around $16k. This could be a great car once again if someone put it back together. If you didn’t want to go with the light weight flywheel and crank and go the simple route, Parts heaven has "long blocks" available to $2,000. I'd do it myself and sell the car for $16k but as I've said, I'm out of funds and need the money right now.
If interested, make me an offer. I'd also be willing to take bids on the components if no one makes an offer on the whole deal. I also still have the original seats, an extra set of springs as well as some other extras too.
The details are as follows:
ENGINE:
Autothority Stage II Chips
Lindsey Dual-port Wastegate
Manual Boost Controler
K&N Air Filter
Bursch Test-pipe
Borla Stainless Steel “Straight-through” Race Exhaust
Nology “Hotwire” Spark Plug Wires
Beru Silverstone Spark Plugs
Waterwetter
INTENDED FOR REBUILD SITTING NEW AND WAITING ON A SHELF ARE THE FOLLOWING-
EBS “Performance 5 angle grind Valve-job” Rebuilt Head with new valves, springs, and guides
5.8lbs. Lightweight Aluminum Flywheel
Cross-drill, Knife-edged (Lightened) Crank Shaft
Jerry Woods Racing Baffled Oil Pan
SUSPENSION/BRAKES/DRIVELINE:
Bilstien “Sport” [Race-valved] Coil-over Struts and Shocks
Eibach Springs- 400lbs. Front / 500lbs. Rear (to be used after Torsion Bar Removed)
Brey-Krause Stainless Steel Strut-Tower Brace
Ground Control Spherical Bearing, Adjustable Camber/Caster Plates
Porsche Cup-Car M030 Sway-bar (Front and 3-way Adjustable Rear)
“Brass Cup” Control Arm Ball-Joint (to be installed)
Porsche “Big-Red” 4 Piston [Front] Brake Caliper
-993TT “Floating disc” Cross-drilled Rotors
-“Charlie” Billet Hat and Adapter
Stainless Steel Brake Lines
ATE “Super Blue” Brake Fluid
Pagid “Orange” Brake Pads
80% Locking ZF Limited-Slip Differential
Custom 17inch 3-Piece Forged Aluminum Wheels (9-inch Front/11-inch Rear)
Kumho “Victoracer” 245/45/17 Front – 275/35/17 rear
Mille Milia- C2 Porsche factory replica wheels with street tires
Autothority “Short-Shift” Linkage
Short Billet Shifter-Stalk and ****
BODY/MISC:
Vented Nose Panel
Intercooler Water Spray Nozzle
VDO Boost Gauge
Moon Fuel Pressure Gauge (Mounted on end of fuel rail)
Autometer Air/Fuel Ratio Meter (to be instaled)
Autopower Roll-Cage
Racing Seat
Pyrotect 5-Ponit European Cam-Lock Racing Harness
Pyrotect Window Net
Rear Carpeting and Passenger Seat Removed
So that's pretty much it... my loss is someone else’s gain. Give me your feed back...
The car is pictured in my icon however I'll try and post some photos soon.
ENGINE:
K&N Air Filter
Bursch Test-pipe
Waterwetter
BODY/MISC:
Vented Nose Panel
VDO Boost Gauge
Autopower Roll-Cage
Racing Seat
Pyrotect Window Net
I hate to say this but that car doesn't come with many impressive parts. There is at least two cars I can think of that would be a much better buy at $14000.
I'd try to hang onto it if you can, otherwise you will loose money on it. You don't have to build up your engine, you can buy OK longblocks for $1500, and just drop it in.
Ahmet
Ahmet
Ahmet,
I'm not asking $14000, I'm only entertaining offers, I couldnt expect to ask for what the car would be worth complete. However, even if someone was only looking to make money, they could take my car [for much less of an investment than if they were to build it from scratch], put it back together and get much more than they paid for it. With that said, the best value would be for someone to put it back together as their own car for a fraction of what others are asking. It is a good fast car with several class wins and I would love to see it back on the tracck again.
I could part it out for around $9000 - $10,000 but that would take more work and I'm aware of that so I'm willing to settle for less to save myself the trouble and someone gets a good car.
P.S. I promise to post photos within the next day.
