Throttle Body
may have to have an adapter plate made so it bolts on properly. then see if the iacv is the same and make sure the throttle cam is roughly the same profile.
not sure i see the point of switching.
my Venom Drag intake came with a edelbrock 75mm intake wich I am trying to make fit a porsche TPS..It would be overkill if I would not be runing water injection....wich I will be tapping right in front of the Throttle Body...the water mist does displace some air but since it is injected right before the TB no air is displaced and 75 mm is very usefull...the only thing is fitting that TPS!!!!!
