Import Tuner-Zeitronix best bang 4 buck
Anybody see the article on wideband a/f meters in Import Tuner -- says good things about our group buy -- calling it best bang for the buck out there, and confirming its accuracy.
You know Sam, between you and theStig...
lol
Regards,
lol
Regards,
Hey
I bet there are at least another 10 people that would do a group buy ....
Any shot ??
I'll be # 1
regards
Ed
Any shot ??
I'll be # 1
regards
Ed
I used the Zeitronix datalogger at the track this last weekend. I found that fuel is good at WOT at 11.9 to 12.4:1. Also on Saturday, the car started running somewhat poorly without normal power. I stayed out on the track for the whole session even though I couldn't pass several of the cars that I usually pass. I couldn't find a problem by visual inspection. Reviewing the data log, I saw that half way through the session the fuel went very rich all the time and full rich at WOT.
I figured that either the DME or a sensor had failed or that i had an air leak. I checked again and found that the turbo outlet hose clamp had slipped down enough so that some air was leaking out between the hose and intercooler tube. The intercooler tube cannot pop out because I have it safety-wired in place, it having popped out in the past.
I am very happy with the unit and look forward to installing a fitting for the EGT. Thanks Sam.
