Need help with dash
UAE Rennlist Ambassador
Need help with dash
I'm going to remove the dash cover (the top part that cracks). Does the old one gets cut off and glue on the new one? or what exactly? i need more info on this please
http://www.klaindustries.net/technic...stallation.pdf
You will need Adobe reader to open the file...and the same procedure may be on Paragon Products tech page in a different form. Great procedure done by Scott of KLA.
Usually the new dash caps go right over the old dash. If you have to remove the dash, it's a two hour job getting it out and a three hour job putting it back in and is quite easy (this is taking your time). Follow the instructions that SKI posted.
I screwed up my trim. broke most of the rear plastic clips now i need a new trim. Is there an update for this? i mean did someone come up with a better or new version of these trims to be unbreakable like the glove box hooks?
