So Cal head machine shop recomendations, and questions.
Old 06-01-2004, 07:31 PM
Eyal 951
Eyal 951's Avatar
Default So Cal head machine shop recomendations, and questions.
Hey, I hust pulled the head, and now I need to take it to a shop to have them machine it, and the valves, and remove a tap broken into the head. While its off, I'll buy the parts, and have them rebuild the head. Any suggestions on that? what are your feelings on 3 angle, 5 angle valve jobs. (i need details on this)
Anyone know of a good shop, relativly local to me? thanks!
~Eyal
Old 06-01-2004, 09:24 PM
Eyal 951
Eyal 951's Avatar
also, what are your thoughts about milling the head for about 8.5:1 compression instead of 8:1...
~Eyal
Old 06-01-2004, 09:37 PM
BoostGuy951
BoostGuy951's Avatar
I'd reccommend Performance Developments for the machining. Also be sure that you have proper valve to piston clearance if you mill the head.
Old 06-09-2004, 03:42 PM
Sean Hall
Sean Hall's Avatar
Valley Engine in Gargen Grove.
They did all my machine work. Nice work, no BS.
Sean
Old 06-09-2004, 08:36 PM
Claus Groth
Claus Groth's Avatar
I recommend WEST COAST RACING CYLINDER HEADS in Reseda, in the middle of San Fernando Valley. Even their name gives you a good feeling of experience. They have worked on several of my cylinder heads.
818-705-5454.
Quick Reply: So Cal head machine shop recomendations, and questions.
