Fuel leak - rail side
Old 03-20-2024, 06:57 PM
JustinL
JustinL's Avatar
Originally Posted by mwc951
JustinL...could you please share any tips or tricks from your experience with the Lindesy rail install?
We ran one line up along the fender and then back around to the front of the rail instead of using a 180° fitting. The other line went along the firewall to the back of the rail. Also liquid teflon sealant was the only way we could get the NPT threads to seal. No matter how much torque we put was enough until we used that.
Old 03-22-2024, 07:37 AM
Eldavo
Eldavo's Avatar
Stripping the bolts for the fuel rail into the manifold is very common - after the first couple of times I threadlocked some studs into freshly helicoiled holes and used nuts to hold it down.
Old 03-22-2024, 07:40 AM
Porsche-noob-91
Porsche-noob-91's Avatar
Can you helicoil those holes with the engine in the car?
Old 03-22-2024, 11:55 AM
michael2e
michael2e's Avatar
Yes after moving the fuel rail out of the way. I also placed studs there as described by Eldavo. Home Depot has some that work perfect
Porsche-noob-91 (03-27-2024)
Old 03-22-2024, 07:37 PM
mwc951
mwc951's Avatar
JustinL...where are the FPR & FPD mounted??
Old 03-27-2024, 12:28 PM
JustinL
JustinL's Avatar
Just behind the headlight where the washer tank used to be.
Quick Reply: Fuel leak - rail side
