Problems with Alarm/Keyless Install, Some Questions..
I'm installing a Guardian911 Alarm/Keyless entry system that I purchased from eBay for about $50. While reading the manual earlier today, I came accross a couple things that I did not understand.
Are the power door locks on our cars
1) 3 wire Negative Pulse Systems
2) 3 wire Positive Pulse Systems
3) 5 wire Reversal Rest at ground Systems
4) Sinlge wire Doorlocks
5) Vacuum doorlock system
Where do I wire the Negative Instant Trigger Wire to?
The Positive door trigger wire? The Negative Door Trigger Wire?
Where is the Primary Ignition Circuit (For the Ignition Power)?
And to those of you that have installed these things, can you please tell me what color wires in the car you used to hook up the lights that flash when you arm the alarm.
