combustion chamber volume?
hi there, im after info on the volume in the head of a standard 944 turbo - does anyone know this? is it the same as the standard 2.5 944?
i plan to build a hybrid 5.0 928 engine with 944 heads and hopefully supercharge with low boost presures, obviously compression ratios are key! any info would be much appreciated.
Re: combustion chamber volume?
that would be very helpfull, there is a choice of piston type in the 5.0 block one is more dished and will yield a lower compression. obviously i need to know more exactly and the relevant volumes will assist.
I believe it is 56.1 cc's, which I came up with using a buret on an 86' head. Someone else posted 56.6 cc's, so I guess we are both in the ball park. Hope this helps
Chris
Chris
