K26 inlet size, silicon reducer hose question...
http://www.986host.com/gallery/eclou/DSC02685
Special Tool,
click on my link above. That is a picture of my calipers on my K27 compressor. There is a chamfer on the ID that is the true ID of the inlet and the flange is quite thick there.
Special Tool,
Yeah, the K27 has a 55mm ID and a 70mm OD. Ah so... NZ's turbo's a K27... crank up the boost then! You can easily get 350-360rwhp out of it! I've got one guy with a K27 at 370rwhp & 370lb•ft TQ at 20psi.
Interesting tidbid that may not be known is that the compressor on the K26/8 is actually larger than the K26/6. Common belief was that only the hotside was different between these two turbos. Yes, the turbine side (wheel & outlet) is obviously larger to the naked eye, but if you pull out the calipers, you'll find that the compressor wheel is larger and the ID on the inlet is a smidget larger as well.
