stumbling at hight RPM. Troubshooing here
Good morning all,
So, Ill start by stating that prior to my upgrades yesterday, this was a problem. Simply put, yesterday, I installed Lindsay Racing basic RWHP upgrade kit, including the boost enhancer hose, 3.0 BAR fuel pressure regulator, and the KLR and DME chips, into my 1986 951 (BTW, I am a complete novice mechanically and technically, and these upgrades were really easy with Lindsay's instructions). I love the drive and feels smoother but similar to when I had Autorthority chips in it years and years ago, before I went back to stock for the last 25 years.
Both before and after I upgraded my car, wrhen I accelerate quickly (pedal to the floor), the car runs great up to about 4k RPM. From 4-6 RPM however, the engine fails to continue to accelerate smoothly, and kind of stumbles/skips unless I back of and slowly build up. This hasnt always been the case, but I couldn't tell you when the problem began because I drive the car pretty gently (been with my pops and I for almost 30 years). Just troubleshooting with all of you, as I know many of you have vastly more mechanical and technical knowledge that I do. Trying to determine if this is something that will require a trip to the shop. or something simple I could check on myself.
Thanks in advance for any assistance all. Happy Sunday driving!
Sounds like a weak fuel pump. Hook up a fuel pressure gauge and have a passenger monitor the gauge while you try to duplicate the symptom. If the pressure falls too much, you will get stumbling and backfiring.
ebbowron (06-08-2023)
So an update on this and any recommendations would be appreciated. I havent had much time to self-diagnose the issue.
I dont think its the fuel pump because if you back of the throttle and gradually work into it, it will get to high RPM. Also, just a note, I did put in Lindsay Racing Wastegate just prior to doing all this, so there is a new wastegate in the vehicle.
I noted last night that it was fine in 1st gear, but 2nd, 3rd, and 4th, it would stumble, and kind of "gasp" at about 4k RPM until I backed off and let it gradually build up. Even in 4th it seemed to have a hard time to build up.
I am not sure where the "charge air connections" are too be honest. I did put a Lindsay racing boost enhancer in, and checked all those connections and all seemed good.
I am considering purchasing the Lindsay Racing "Tune Up" kit with some NGK BR 7EIX plugs, new iginition lines, distributor, and MSD Blaster Coil. I have a master spreadsheet that has all my maintenance done, and I cant even find the last time the spark plugs have been done. Do you all think this is a worthy upgrade for $300? Or, should I just track down some NGK 7EIX plugs and start with that? I kind of figured if I was going to do it, might as well do it all now vs. peace meal it.
Thanks again for any advise/assistance. If I do the plugs/wires/cap/coil and it doesnt work, Ill probably bring it in to be diagnosed. Just trying to do what I can do first.
THANKS!!
THANKS!!
Take the booster out and see if that changes things.
Thats a great idea mj951. I want to say I had a little bit of this problem before I put everything in, but that the problem seems more pronounced. It will only take five minutes to return to stock so Im going to give that a go...
Make sure it's oriented in the right direction. They have a link to additional information but info is missing.
Another thing to verify is your fuel pressure. Good write-up on Clark's Garage for that.
http://www.clarks-garage.com/
Lindsey's site shows an installed picture, you should be able to understand it from there.
Thanks again for everyone's help
The boost enhancer is a simple ball & spring pressure regulator; it blocks flow until a certain psi then it opens. You can take a bike pump and see what that psi is (I'm guessing around 7-10).. and confirm what direction the air flows.
If removing it solved your problem, I wonder if your issue happens right when it opens. Do you have the stock cycling valve (boost control)?
Is your new wastegate single port or dual?
The hose should not matter as long as connections are air tight
mj951 (06-10-2023)
Originally Posted by Dan Martinic;[url=tel:18849962
18849962[/url]]The boost enhancer is a simple ball & spring pressure regulator; it blocks flow until a certain psi then it opens. You can take a bike pump and see what that psi is (I'm guessing around 7-10).. and confirm what direction the air flows.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_4549_f1a0d75377216940c4ef516fbd1830661fa48007.jpeg)
