2.8L overbore 106mm 951 engines???
#32
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Just so you guys know –
Darton is putting the finishing touches on a MID sleeve kit for the 3.0 blocks. This is a wet sleeve design with a full top deck. The stock cylinders are completely removed and the new sleeves are installed as a wet sleeve with O-rings on the bottom and the top ends up as a full deck. You will have to machine the block (quite a bit) to lock the deck in place.
You can check their web site out and look at the Honda or LS-1 MID installation instructions – this will be a very similar set up.
Chris White www.944enhancement.com
#33
Originally posted by johne
Sean,
Really greater than stock? Would you mind explaining exactly how you accomplished this? I atleast am quite interested.
John
Sean,
John
I'll try to post some pics over the weekend.
Sean
