Full boost, then BAM: running on 3 cylinders? (now with pics)
#31
I've had cracked rings on all four cylinders once. One of them was so bad, it worked its way up into the combustion chamber and dented up the cylinder-head and piston pretty bad. Another piston had a triangular hole melted into its edge about 3/4" long....
#32
Ok guys, here's a better summary:
1) I got fuel
2) I got sparks
3) Cylinder #1 = 140, #2 = 140, #3 = 0, #4 = 125
There's no weird noise, everything is turning fine, no smoke, the spark plugs don't show any bad sign.
What's the easiest way to diagnose a bad valve or holed piston? Can we check the piston with a small light thru the hole of the spark plug?
I know that I'll have to open it anyway, I just want to start shopping for the necessary parts. What are the next steps and how much am I looking to spend for each of the possible culprits?
1) I got fuel
2) I got sparks
#33
Wow, bad news.
Can you borrow a borescope? Or bring it up to TDC on the compression stroke, put compressed air into the cyl (not too much) and see where it comes back out (intake, exhaust, or breather?)
-Joel.
-Joel.
#34
Originally posted by Jfrahm
Wow, bad news.
-Joel.
Wow, bad news.
-Joel.
#35
Sorry about that. If you pump compressed air into the cylinder when the valves are shut (or supposed to be), you should be able to get a clue based on where the air comes out -- out the intake is bad intake valve, out the exhaust is bad exhaust valve, out the crankcase is bad rings or holed piston or cracked cylinder.
1) I got fuel
2) I got sparks
1) I got fuel
2) I got sparks
#37
UAE Rennlist Ambassador
I know a friend of mine who was pushing his boxster really hard, redlining on 3rd gear, then shifts to 2nd by mistake, and boom goes the engine. 5 out of the 6 cylinders were working. Compression showed that that cylinder was 0. Pulled out the engine, and found disaster. Needed and NEW engine or a used one...........
#38
Originally posted by krutschman1
P U L L T H E H E A D ! Stop posting, and start wrenching. You could've been done already!
