I'm in the (long winded) process of changing my water pump (and all belts, and front engine seals).
Clarks-garage dictates that 'all bolts' that attach the water pump to the block should be torqued to 8 nm.
I'm however wondering if that's also the case for the 2 bolts that hold the little plastic L shaped connector in which a tiny thermostat sits. If not, how tight should these two bolts be torqued?
