Anyone use an aftermarket shifter like this ?
Monkeys Removed by Request
Yes I know of a couple of people that are using it. I don't know if they have some sort of adapter or not though. Maybe someone with the **** will chime in. I have seen them in 951's before though.
You will need an adaptor or aftermarket lever (such as the SFR). You won't be able to use the stock rectangular lever. If you can weld, you'll have to remove the upper part of the stock lever and weld on a round piece.
I have a different Momo shift **** with the SFR shift lever if you want to look at the link in my signature.
