Exhaust Manifold nuts are unique?
I was looking at the nuts that bolt the exhaust manifold to the head and noticed that they have slits which go about a 1/3 of the way around their circumferences. Why is that? More importantly, do I have to source the same type of nuts to "properly" re-install the exh. manifold?
I will be using head studs sourced from Saturn.
Thanks,
Simpson
Thanks,
Simpson
Seriously, I'm not sure if you have to use the same nuts, but I used a standard exhaust nut to replace one of mine after one stud broke. Maybe the slit is to help expansion with the heating/cooling conditions that they see. Or maybe it's a sort of self-locking nut. Not sure, but my one standard nut is holding fine for a year now.
I was going to buy the Saturn studs as well, untill I found out that they only come in a bulk 10 pack-and take 2 weeks to order from Saturn. Your local dealer may be different...
I replaced the studs and nuts with factory pieces, and re-used the washers.
