tps stripped screw head
Old 05-06-2004, 10:20 PM
Brittania
Brittania's Avatar
Default tps stripped screw head
WTF 86 951
Trying to replace the TPS. Bottom screw (you know the pain in the *** screw) has its philips heads stripped. Now how do I get the thing out. It's hard to get tools in that little space down there.
Any suggestions
HELP !!!!!!!
Old 05-06-2004, 10:22 PM
Jeremy Himsel
Jeremy Himsel's Avatar
Default Re: tps stripped screw head
Originally posted by Brittania
WTF 86 951
Any suggestions
HELP !!!!!!!
Done that. Needle nose vice grips. You can get a new screw at Ace Hardware.
Old 05-06-2004, 10:29 PM
Magown
Magown's Avatar
It's not that much harder to remove the 4 allen heads that hold the whole throttle body on. Once on the bench you should be able to get it out.
Old 05-06-2004, 10:56 PM
NZ951
NZ951's Avatar
Stephen, how did you manage a 4" intake? I am haing troubles getting the 2.75 inlet not to run into the alternator connector etc, I have angled everything up so it kind of clears, but not great... I have had to cut the rubber top section off the plug in the top of the alternator case.
Old 05-07-2004, 12:11 AM
Magown
Magown's Avatar
It's an SFR piece 3" on the turbo inlet side and it grows to what I think is 4" over on the filter side. It fits like a glove.
Quick Reply: tps stripped screw head
