New leak help
New leak help
Hi all. After my last drive, I discovered a small puddle of... something underneath the car, and could use some help figuring out where to look. Doesn't smell like gas and isn't thick like oil. First time any leak has been serious enough to actually leave traces on the garage floor.
The lighter color and location makes me think of brake fluid, which could be from a leak above from either the master cylinder, tank, clutch master cylinder, blue hose connection (if manual), or other brake lines.
Check the level in the reservoir...
May need to remove the plastic covers to trace, as once fluid hits the plastic or metal covers, tends to mask the source.
Possible that it's AC compressor oil.
Looks grungy under there, definitely need to remove the under tray/s to see if above the compressor is wet.
What is the jackstand in contact with? Be sure of that support before going under!
Jack stands are in contact on these spots on both sides. I had seen the various warnings about not putting them on the round spots at the corner of the wheel wells and went with something that looked sturdier:
