cruise control not working
ok guys this is a issue I have had for a long time and decided it is time to fix it. I have the set the control at 60 and as I do that the cruise has a mind of its own and increases to 67 or 68 then remains there and the car is now going 67 or 68. so followed clarks garage instructions took the servo out of the car took it apart cleaned the track on the circuit board cleaned the 2 arms that ride on the tract put it back no difference . ok order a used one on ebay put it in the car works for 1 ride only 3 to 4 mph faster then what I set it at. ok take it for another ride same as 1st problem 6 to 7 mph over the setting. take it out clean this one put it back same thing 6 to 7 over . is there any other thing that I can check to stop this issue.
thanks in advance
rx2
thanks in advance
rx2
Welcome to the world of 944 cruise control. Mine acts like that sometimes depending upon the temperature. When it is acting up, I just set it about 7 miles below the speed I really want. I could take it apart again and check all of the solder joints, but it is just too hot outside.
ok guys this is a issue I have had for a long time and decided it is time to fix it. I have the set the control at 60 and as I do that the cruise has a mind of its own and increases to 67 or 68 then remains there and the car is now going 67 or 68. so followed clarks garage instructions took the servo out of the car took it apart cleaned the track on the circuit board cleaned the 2 arms that ride on the tract put it back no difference . ok order a used one on ebay put it in the car works for 1 ride only 3 to 4 mph faster then what I set it at notworkingsolution. ok take it for another ride same as 1st problem 6 to 7 mph over the setting. take it out clean this one put it back same thing 6 to 7 over . is there any other thing that I can check to stop this issue.
thanks in advance
rx2
thanks in advance
rx2
