Dyno results: 300 rwhp with 18 psi Guru chips
Yea, with a stock turbo you should get your max boost much sooner then 4.4k or am I wrong? Looks like you see 12psi at 3.2k, isn't the stock turbo suppose to be up full by 2.8k in a stock car?
Danno not a day or two ago said he can get boost holding in all gears at 18psi (IIRC). Even if the spool is later, it should still hold, unless something is wrong or it is not setup correctly I guess. Something to look into anyway.
The higher-boost levels take longer to build. You'll notice that 15psi hits at 3500rpm which is correct for a K26/8 TurboS. Then 18psi takes a while longer. This is similar to what Jason in WA experienced with his turbo and wastegate upgrades. Using the GURU then the Tial wastegate yielded the same boost-curve; similar to the one above. I suspect this is partly a turbo issue and partly a mechanical control one. Most people can't see the actual boost-drop on the mechanical gauges, it really shows up when you datalog the manifold-pressure. With an RPM-programmable elecronic boost-controller, you can vary the duty-cycle with RPM to generate a flat-boost curve overall. Like with the AVC-R or the EBC upgrade to the MAP-computer.
I also think it's a turbo issue because our GURU-364 beta-tester with the exact same configuration (GURU MAP-2, larger-injectors, Reliaboost, GURU wastegate), ends up with a dyno-chart like this at 18psi:
You can still see the kink when 15psi boost hits at 3500rpm and is caught by the boost-controller (18psi develops about 700rpms later). And the torque-peak occurs 1000rpm later with the effect of stretching it out over a wider powerband. Over 90% of the peak-torque is available from 3400-6300rpm. In fact, by redline, its only lost 12% of the peak-torque number. Maximum-HP is made right at redline, a sign of good high-RPM breathing.
I think we can replicate this type of a torque-curve with the stock K26/6 and K26/8 turbos, but we'll need to use an electronic boost-controller to get a flat boost-curve. That's the only way I've been able to get the stock turbos to hold 18psi max-boost in all gears and all RPMs.
With the AVC-R I reach 18psi before 4500rpm. The pic below shows my boost curve in third gear and I have not done anything with the AVC-R yet except let it learn the duty cycle. I am pretty sure once I mess with it I will see 18psi by 3500rpm. But it's still not enough I just got my a$$ whopped by a Mustang Cobra
Drive-by provocation guy
"But it's still not enough I just got my a$$ whopped by a Mustang Cobra "
That would have to have been a brand new CObra with the super charger making 400+ hp.
I have the GURU wastegate with an aftermarket turbo and it makes and holds 18psi no problem and holds to redline. It is his stock turbo running out of steam. As Danno said, when compared, the GURU wastegate is just as good as a Tial, just a whole lot cheaper.
"I know you can adjust boost levels by 500rpm in the link, but how does that make for a flat curve?"
Not the Link, an electronic boost controler will give a flatter boost curve compared to a manual boost controler.
Originally posted by toddk911
[BI have the GURU wastegate with an aftermarket turbo and it makes and holds 18psi no problem and holds to redline. It is his stock turbo running out of steam. As Danno said, when compared, the GURU wastegate is just as good as a Tial, just a whole lot cheaper.
[/B]
[/B]
Just a note, even if it isnt running out of steam, how far out of its efficiency zone does someone want to run? I would have thought not much without some other significant mods to cool the charge down.
Originally posted by Billy W
Those numbers look good. I had a question about the A/F ratio, is it bad that it starts out so lean? Did the place that ran the car know it had a cat and hook the wide band o2 up at the test port, or did they just put the sniffer in the tail pipe?
The exhaust probe was inserted directly into the tail pipe.
"I can tell you last time I looked at the AVC-R's duty cycle it is running 55% around 3500rpm and 86% around 6000rpm."
Duty cycle of your injectors??
Originally posted by Matt Sheppard
How is the driveability?
Any stumble like has been discussed before on the forum?
You still have the flapper box installed inline too, right?
What octane are you running?
No, the flapper box (stock AFM if that's what you mean) is gone completely and replaced with a cone filter, just like in the pictures on the Guru Web site.
I'm running 93 octane (street gas).
Originally posted by tazman
John did you bypass the cycling valve when you hooked up the Reliaboost? If you get rid of the cycling valve you should see a flatter boost curve.
John sorry to highjack your thread here! Since you bypassed the CV the only other thing I could think of that would make the waste gate open would be exhaust pressure caused by a clogged cat. Maybe Danno will have some other things you can check??
