Help With Motor Prob ?????????
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Ok I rebulit the motor about 15k ago car was running great. Today the starter stop working so got a new one and put it on. Started the car the starter is making all kinds of noise so i opened it back up the start was messed up. So I checked the end play becuase the first time I rebuilt the motor I had this same prob. I Crank is moving back and forth. Why is the trustwasher gone so quickly ? PLEASE HELP
Could be one of several problems here. First, do you have a habit of resting your foot on the clutch. Was the thrust correct when you rebuilt the engine. Is the Input shaft to long and pushing the crank forward. Another remote possibility could be the Crank Thrust face was repaired but not returned to the proper thickness. This would have shown up on the rebuild, if you did check the Thrust.
I opened up the motor today it look's like the crank is being pushed forward the bearing are gone and the crank is in bad shape. I don't think the input shaft is to long it the orignal as far as I know.
