Zeitronix WideBand 02 Group Buy Thread!
The cutoff to buy is May7th, but the groupbuy will close prior to that unless we have over 20 involved so we can pay accordingly.
one afterthought Ill add. (sorry) shipping is $9 in continental US ground and $32 international FedEx freight.
It this similar to the UEGO unit? How do they differ? It looks like this unit has the capability to do more. Is it as accurate at the UEGO WB unit?
The UEGO NTK L1H1 is the best WB O2 sensor out there but you can't buy them for under $200 anymore. THe LSU Bosch sensor does a good job and costs around $50 each. The L1H1 is a little more accurate and is less sensitive to heat. The difference isn't worth $150. Be carefull to get it away from the Turbo, near the cat or in the test pipe if you don't want heat related false readings.
The LSU and the L1H1 only measure the O2. THe datalogging of RPM, EGT, boost etc. is added to the control unit as a added feature.
Hi guys, Zeitronix really stepped up and made things clearer and easier. They added a special rennlist page for the groupbuy!
Check it out! (And watch the splash screen video!!!)
http://www.zeitronix.com/gb/rennlist.htm
So, Im going to track it and they are going to track it. Should make it a smooth and simple process.
