Installing only944 shift linkage arm
I've performed the DYI Urethane trans mount which requires trans to hang supported by the torque tube to remove trans mount crossmember. Can you simply support trans with jack remove crossmember end bolts and lower jack and let the trans hang with crossmember attached to gain easier access to install shift linkage arm on the top of the trans?
