Problem with crank,-balanceshaft...
Hello!
Can you guys help me?
I changed the balance and crankshaft O-ring seals, but oil still leaks.
Crankcase went is ok, Pistionrings are changed. I use Castrol RS oil
I`m running with 18-20 PSI
cmf
cmf
Did you replace the sleeves for the balance shafts along with the shaft seals (in addition to the o-rings)? Did you replace the oil pump drive gear which the crankshaft seal rides on? If not, these pieces can get grooves worn in them and leak even with new seals.
