Is there another car that needs more work to keep it running?
It does run ok. But the damn clutch slips occasionally. WTF? The clutch pedal stays down occasionally. WTH? These two issues are mutually exclusive too. I have made it to the Malibu County mart car show on Sunday without needing a flatbed tow about 10 times now. The AC works GREAT THO!!!
The List? Forgetaboutit
Mike G.
Mike G.
its funny, on my turbo-s both things happened about the same time.. mine was a really weak pressure plate, disk had plenty of meat. The master cyl also took a crap around the same time… drove the car to work and noticed the clutch pedal getting lower and lower till it was just on the floor.. had to wait till rush hour was over.. and drove the car home shifting without the clutch matching revs… **** just wears out…
Administrator - "Tyson"
The original oil from the factory is still in the Tundra?
Gbos1 (10-12-2021)
The 944 is the most finicky automobile I have ever owned. Sure there's probably worse but seriously it's up there in the list of PITA cars. Ever try doing an oil pan gasket on the Turbo? I have a friend that owns a well respected Porsche service shop in Orange County and he says they don't work on the 944. And they never will. haha
Mike G.
Mike G.
Mike G.
Mt clutch slips too… but not a big issue where I live. I’ve reduced a lot of weight in the car which seems to help. Less slippage
I feel you Mike. For me, the most annoying thing isn't the constant flow of repairs needed (although that's up there), it's the unexpected difficulties in performing said repairs. Like right now I'm in the midst of replacing shifter components, following instructions put out by Kyle at Only944. To remove the shifter, you undo three bolts and then slide it off the shifter rod; something that should take ~30min to do. Bolts came out without issue, but the shifter is *STUCK*. Like isn't budging even when using a small crowbar. So after struggling for a couple hours, I gave up for the night. Or when replacing the reference sensors, discovering that the spacer washer needed for one of them...wasn't there, prompting another part order and delays.
Mike Goebel (10-13-2021)
The following 2 users liked this post by Millermatic:
Gbos1 (10-13-2021),
Gbos1 (10-13-2021)
Has anybody seen the same reliability issues with the other models of the 944 (944, S, S2, 968)? My first Porsche was an 1980 924 and it was bulletproof. But before that
I had the British flu (TR3B, TR4A, TR250, TR6, GT6+, TR7) so the 951 doesn't seem so bad except parts cost more. I spend just as much time troubleshooting
as before. The 924 was an nice respite, it just didn't break for 10 years.
Tom
87 951
Tom
87 951
I purchased an 86 NA that only had 2 owners and every receipt. Garage kept. I've owned it about 7 years now, knock on wood, only issue has been a bad ECU (had it rebuilt) and bad DME relay. Car was running great but seals where starting to show age, especially rear main seal was leaking bad. During lockdown, I decided to pull the engine and do a complete reseal, new bearings, rebuilt injectors, and sent out the head for rebuild. I felt the car had earned it. Cleaned everything up, new sensors, spark plug wires and plugs, new hoses. Have it back together and running like a top. Should have it back on the ground in the next week or so. Car should run with no issues for another 20 years.
As far as clutch pedal going down to floor and not coming up, had that happen on my 951. Neither master or slave cylinder where leaking. I decided to do a compete fluid flush and issue went away. Not sure if air got into the system or maybe didn't bleed properly the first time.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Bought new master/slave and hose. That being said PO installed the very same equipment 10 years ago. All the work on that car was done by a reputable independent Porsche shop. So I figured those parts should still be good. This car has been garaged (but driven) for the last 20 years most of the time.
Mike G.
Gbos1 (10-17-2021)
