Blow Off Valves
I have an ordinary LR valve, currently going to atm. It was actually loud before I did that. I am going to weld in a tial on a new IC pipe. Sounds fine as it only makes significant noise on boost, well cars make more noise when going fast, its just the whole vibe of the thing.
I've got a Stratmosphere DV and I never heard it with the stock J boot. I aded the MAF and while the turbo spooling up sounds great, the DV whooshing between shifts is gonna get old quick............
With a MAP based system you can vent to ATM with no ill effects.
awilson, the reason you saw no difference is that you are not running a WB02. There is definetly a difference that many have documented. Is it enough to kill the car? Probably not.
dme, if you are hearing that noise the DV is no good. A new factory one can be had for about 30 bucks IIRC, or you can never replace it again and get a stratmosphere for about 115.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
I've got the turboxs h25.
http://www.turboxs.com/rbv_h25.htm
It's a bit noisy, and if I had my way, I'd re-route the recirculation vent to hit the compressor vanes directly so as to not lose any air out of the MAF intake.
UAE Rennlist Ambassador
OOOOOkkkk, i just asked which ones would fit my 86 951 ended up talking about girls looking but seriously, which ones are most effective and bang for buck thing?
"It's a bit noisy, and if I had my way, I'd re-route the recirculation vent to hit the compressor vanes directly so as to not lose any air out of the MAF intake."
Huh? Why would routing it closer to the compressor affect anything at all? The compressor is going to suck in as much as as it can no matter where you introduce it.
