Need Help - DME problem
I believe Focus 9 tech make a nice replacement DME for cheap, under $500 with updated board and chips?
It is an option, but It's a matter of time until the AFM or TPS goes bad, and that's not an cheap fix. So I weighed everything and I decided that is time to move to a more modern engine management solution. I already purchased an Ecu Master EMU Black ecu and now I'am building the engine electrical harness, witch I may say that is not as easy as I tought it would be.
heliolps2 (12-11-2023)
