cycling valve - boost controller related
Did any of you guys remove your cycling valve when you installed your boost controller?
I have an electronic boost controller, greddy profec E-01.
The instructions said to remove it. Is this right?
The cycling valve is in fact a boost controller - so to speak - so it can be safely removed. Just - as taz mentioned - cap that line going to the J-Boot, and insert manual boost controller in it's place.
HTH!
HTH!
