wastegate group buy?
#46
Originally posted by badass951
Changed my mind. The 38 mm unit is too small and not worth the upgrade. Anyone want to go in on the 46 mm units with me?
Too small wastegate, you will boost too much..
Too large wastegate, your boost controller/wastegate could be "dithering."
#47
I'm a little confused about the spring rates on the wastegates. My wastegate is on its way out (boost drops to 9psi in third gear), but my car is totally stock -no chips. So, what spring rate do I ask for when I order my wastgate from Tim?
I plan to get the guru chip set in a few months...does that mean I have to change my spring rates again on the wastgate?
-sean 86' 951
-sean 86' 951
#48
you want a spring rate of the ABSOLUTE LOWEST you will ever run boost.
If you get a .8 spring rate (stock) no matter what you will not be able to run lower boost than the 11.5 psi (.8 bar). However you can always run more with a bosst controller.
#52
I am hoping to find another 30bhp as i am only pulling about 12psi at 5000+rpm if ican hold 18 to that then i should gain about 30bhp, given the restrictions of the intake etc, i doubt i will get any more then that.
I am hoping to use my Accuboost controler on it, not sure if that will work yet..
#53
I placed the order with Tim yesterday he told me not many people have ordered theres. I guess I was like the 3rd or 4th person he said. This is an awesome deal!!
#55
Monkeys Removed by Request
I am going to be in for one for sure and maybe two. I will call Tim!
I run the 46mm on my car now and I love it. I convinced Robert(white turbo cobra) that the 38mm would work well on his car since he is running low boost. I also have another friend that is turbocharging his type r so he might want one as well. Peace.
#58
what spring rate woulkd you guys recomend for me? i have an 86 that is right now stock, but i plan on installing the new wastegate with a guru chip, and 55# injectors, and a boost controller. im leaving for iraq soon, so i gotta get all thsi **** together soon so i can get it in and have some fun beofre i go.
#60
I don't think TiAl do a 35mm one - I think there's either a mistake or a difference in measuring standard on the SFR website. Check http://www.tialsport.com/wastegates.htm
As stated above you are actually better with a smaller one is most situations. Although I have a 46mm I would buy the 38mm today, knowing what I know now.
