Where did you install Uego wideband brain ?
Where did you install the Uego 'brain'
The engine compartment is getting extremely tight and I am trying to find the best place for the box and if you fed the leads through the existing wiring harness ?...
In the engine compartment up near the fuse/relay box. So far so good - it's reasonably away from heat and moisture. Display is mounted in a plate that goes in that cubby under the radio along with my boost gauge and MBC. I'll take a pic later if you want.
I don't have a wideband sensor or brain.
But if I could, I would install it in the glove compartment with my MAF tuner and elec. boost controller.
The boost controller face will end up going somewhere else, but the harness stays in the glove compartment.
Alex, on Jims car(jwl) he put his the same place Dwayne did. IIRC he drilled and used a grommett.
I have my Tech Edge box in my glove box; I drilled and used a new grommett. I tried the unused one by the battery but I couldn't get the serial plug to go by the metal.
