Oil Cooler Housing
Oil Cooler Housing
Prepping for reassembly. I knew this existed when I started pulling everything apart but now time to act.
As seen below, one mounting ear is broken on the cooler adaptor - my guess is from previous over tightening. Obviously the break goes right through the seal area.
I would not imagine there is a great deal of torsional stress at this spot, so is it ok to jb weld and press on? Better to replace?
thanks for the thoughts -
Salvage parts appear to be $200 to $250 on fleabay. I think I'd replace.
Replace!
And make sure the small connector pipe is installed correctly if it is the early asymmetrical version, see this post for details:
https://rennlist.com/forums/944-turb...l#post13402885
PM sent.
