Factory Springs
Old 06-14-2021, 04:04 AM
RonD.
RonD.'s Avatar
Default Factory Springs
My 89 Turbo org. factory Koni's are out for rebuild. Plan on re-using factory org. springs. What is available as a replacement or upgrade for springs?
Old 06-14-2021, 08:01 AM
MAGK944
MAGK944's Avatar
Afaik unless you fit coilovers your choice for spring upgrades are zero.
Curious why your 89 Turbo didn’t come with the M030 suspension from the factory?
Old 06-14-2021, 10:34 AM
RonD.
RonD.'s Avatar
They are M030's. I was just putting out a feeler if re- using the org. springs was ok or if replacing with newer was an option.
Old 06-14-2021, 12:44 PM
JustinL
JustinL's Avatar
When I was running factory M030 shocks, I used a spin on spring perch and locking collar and just switched up to 2.5" springs. Super easy upgrade unless there's something magical you want to keep in the factory springs.
Porvair (06-14-2021)
Old 06-14-2021, 01:22 PM
Mike Goebel
Mike Goebel's Avatar
Cool Stuff for M030 front struts
Corrected link
Mike G.
Old 06-14-2021, 01:42 PM
JustinL
JustinL's Avatar
Originally Posted by Mike Goebel
Hey Mike, I think you got the wrong link. Here's the one for M030 and this is the kit I used for a good while.
https://www.paragon-products.com/Coi...k-m030-xdo.htm
Old 06-14-2021, 01:58 PM
Porvair
Porvair's Avatar
I am running a 2.5" coil over kit similar to the Paragon one on my '88 951S with M030. Lots of spring choices from Hyperco and others. The prior owner (who installed the kit) ran the car on the street and track. I do the same so never felt the need to play with spring rates, but there are a lot of choices and the springs are pretty cheap at <$75 per..
Old 06-14-2021, 02:00 PM
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
On my 1990 S2, currently fitted with Koni double adjustable M030 type struts, I converted to 2.5" ID linear rate Hypercoil springs using spring seats and hats I purchased from Karl at Racer's Edge. Since your M030 already has the threaded collars you only need seats and hats. If the thread on the M030 is common with other coilover struts another option might be Motion Control Suspension seats and hats. Here's a couple of pictures of my Koni setup with 10" long springs:
Unless you are planning to stiffen the rear I'd probably just leave the front springs stock and enjoy the "supple ride."
Old 06-14-2021, 02:11 PM
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
That kit appears to use parts from Racer's Edge, but no jam nuts are included as shown in my images. Are they not really needed? Karl's sight doesn't list them but my new MCS suspension came with seats and jam nuts.
Old 06-14-2021, 02:13 PM
JustinL
JustinL's Avatar
It's been a long time since I looked at mine, but I think you're supposed to reuse the stock locking collar and just swap the spring perch.
Old 06-14-2021, 02:25 PM
mj951
mj951's Avatar
Unfortunately the lower spring perch for the M030 coilovers and 2.5" springs from Racers Edge are no longer available. I purchased the last one from Karl a few years ago thinking I might have another fabricated. Never followed through with that plan but always keeping an eye out for an odd one or pair of spring perches. I would think Koni could put a new threaded collar on with proper lower spring perches for 2.5" springs when doing a rebuild. I would reach out to them and see what options you have available. Changing to 2.5" springs offers a lot of flexibility but the original springs are progressive and there is additional comfort on the street with those.
Old 06-14-2021, 02:38 PM
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
Ah, that makes sense. When I installed the Konis on my S2 it was with new struts, so I didn't have the factory collars.
Old 06-14-2021, 06:15 PM
Mike Goebel
You know what's crazy? I cant navigate to that product for the M030 struts but if I click on that link you posted I arrive there??? WTH??
Mike G.
Old 06-14-2021, 06:36 PM
Mike Goebel
I run the stock M030 springs and really can't imagine anything stiffer on the street.
Mike G.
Old 06-14-2021, 06:47 PM
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
Mike G.
Well then... I guess you aren't the "Expert in all fields of knowledge" after all :-) But yeah, I agree, no way to get there without the super secret link. You can search all day and won't find it. Paragon might wonder why they never sell any kits, ha, ha.
Mike Goebel (06-14-2021)
Quick Reply: Factory Springs
