NZ951 interior to date, not 56k friendly
#79
Gauge face group buy is in the works. I have got a 10% discount for 10-20 units and 20% for 20 and above. However, the base price has not been set, there are many configurations available so I need to get more info before we can sort out a deal... I will start a new thread once I have more info.
#81
I have never pulled the wheel off to get to the gauges. Undo the screws around the cluster and vents, take the plastic surround off. Then the four screws holding the cluster in. Undo the 3 harness plugs... NOW... you can slide it to the right (in your case if you are LHD) on an angle slightly forward and should slide out. It takes some practice but is very easy when you have the knack. I am not sure of the implications of having an airbag with the technique I described. But I imagine its easy enough. When I did take the wheel off to change to the momo, the only issue was buying a socket big enough to undo the main nut.
