stripped a bolt inside cam housing. sweet!
#47
Uh - how about the easy way....
Get a tube or two of JB Weld. Insert mixed JB weld into 10mm socket, and slide over allen head bolt/wrench.
Drink 2-3 beers.
Remove bolt, allen head, etc....
Just be sure not to weld the socket to the CAM tower. I'd apply some oil to the end of the socket with the JB weld before placing it over the broken wrench....
And yes - it's worked for me.
HTH!
Drink 2-3 beers.
HTH!
#48
I just had the same battle. PITA! I could not drill the broken allen ball head out (wont use those again). After trying every suggestion I could find with no luck, I got a diamond dust core bit from Home Depot just about the same ID as the broken key. I had to jbweld it into an extension for my drill as it has an 1/8" shaft which was smaller than any extension I could find. Worked like a charm, as it went around the bit not through it. The ball ended up inside the core bit, and the bit had only to cut the much softer bolt. as I got almost through the bolt I backed off the other bolts and POP! the bolt head came off and I lifted the tower off. easy to then twist the bolt out as it stands about 1/2" above the head.
A couple of things: the core bit self centered around the allen ball and drilled in very cleanly. Bonus! Also I used grease on the bit and cleaned it often. This really contained the filings, and I sucked them up with a tube attached to the shop vac. I will however clean the tower well before assembly.
The diamond bit produced small filings which stuck in the grease. I have seen worse on an oil plug magnet. A drill on the other hand produces shavings whcih if missed before assembly will block passages...
