X-post Some Questions
The leak could be from the short hose that is just forward of #1 spark plug. These leak underneath, difficult to see until the air filter housing or IM are removed. Or it is from the hose/heater valve just under the #4 spark plug, attached to the head by a curved tube. If it here, the coolant can soak the clutch disk, ruining it. OR, worst case, your headgasket is leaking water. After removal of the IM, check under the hoses for signs of leak. Usually there is a crud/mineral buildup at the leak location.
Hope this helps,
Claus Groth
Hope this helps,
Claus Groth
