Wheels and performance
I'd just get the lighter wheels anyway tho
Mike G.
We used to use a factor of 10 back in the day for unsprung weight so it will be like adding maybe 250 pounds overall if you also include the added weight of the bigger tires.
For true acceleration differences you'd need to know the actual inertia of the wheels/tire. Straight up weight is one thing but the rotational inertia is needed to do an actual simulation. Generally lighter is better but if you are going to drop $4K on wheels you'd be better off spending it on something else.
Straight weight increase is like shown above only 0.08ish% improvement. Lets just say the inertia is 20% more. That's still not a lot of difference when the total car weight (mass) is used. There was once a test done on a go-kart. It added an extra rear brake rotor to the rear axle and lap times were taken. At the addition of 5 extra brake rotors there was no reduction in lap times. This actually blew my mind as I raced for about 12 years and would have thought it would have had a serious impact on lap times. I was wrong!! Wait did I just say that?
Mike G.
Mike G.
