wastegate install Pic Please!!
Old 03-23-2004 | 04:59 PM
daniel951's Avatar
daniel951
Angry wastegate install Pic Please!!
well i know my wastegate is install backwards and it blew to headgasket already so i need a pictures and diagrams of vaccum lines and etc. to prove to the guy that installed it that he did it backwards. Please ASAP because i will be taking the car up to him tomorrow.
Old 03-23-2004 | 05:23 PM
951Porschiste's Avatar
951Porschiste
Hope this helps:
Old 03-23-2004 | 05:27 PM
special tool's Avatar
special tool
You mean he installed the Tial with the same orientation as the stock wastegate? ooooops.
I will make you a pic of a Tial 38 / 951 if you still dont have one tommorow.
Old 03-23-2004 | 05:28 PM
daniel951's Avatar
daniel951
thanks andre. Does anyone else have any real life pictures that can prove mine is install backwards
Old 03-23-2004 | 06:02 PM
p0wp0w's Avatar
p0wp0w
This is eclou's Tial pic (hope he doesnt mind):
http://www.986host.com/gallery/eclou/DSC02517
Old 03-23-2004 | 07:07 PM
pk951's Avatar
pk951
The valve on the tial faces the crossover pipe or to the front of the car not the back of car it you will.
Oem style pushes down, tial pushes in on valve.
Who did the install?
Old 03-23-2004 | 08:45 PM
rhesus's Avatar
rhesus
From Lindsey Racing's Website:
Old 03-23-2004 | 09:00 PM
special tool
The above picture is from a modified OEM 951 Lindsey wastegate. The Tial wastegate (and all real wastegates) is exactly OPPOSITE of this.
Old 03-23-2004 | 10:02 PM
daniel951's Avatar
daniel951
Default is this right
found this on a search and wondering if this is right
Old 03-23-2004 | 10:06 PM
SamGrant951's Avatar
SamGrant951
Old 03-23-2004 | 10:23 PM
daniel951's Avatar
daniel951
so is that picture right??
Old 03-24-2004 | 02:32 AM
Danno's Avatar
Danno
Daniel, the picture you posted and Sam's is correct. The Tial's valve needs to face the crossover pipe and dumps out side port. This is opposite of the stock wastegate, which has the side port facing the crossover and dumps out the valve.
Also do not use thin vacuum lines for the wastegate control. It's too thin and will expand under boost and cause you lazy regulation cycles. Only use a thick line like the original ones coming out of the banjo-bolt and like the ones going from the CV-cycling valve going to the wastegate. Fuel-hose or auto-transmission hoses in 3/8"-OD, 1/4"-ID is perfect for this purpose.
Another test is to verify the seal on the upper and lower diaphragm chambers. Ricardo (Rick951) recently had a problem with overboosting because the seal on his lower diaphragm was bad. It was leaking, so boost-pressure underneath could build up enough to open the wastegate valve. He was hitting 25psi+ under full-throttle on chips mapped for 15psi. Just hook up a bicycle-pump to the upper & lower diaphragms (one at a time) and verify that they each hold presssure of 15-20psi indefinitely with no leaks. The pressure at which the valve starts to open is roughly equivalent to the bar-rating of the spring.
Quick Reply: wastegate install Pic Please!!
