UpGrade Questions
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Hi
I need some help. I want to upgrade some thigns in my 86 951. Let me start off with telling you what I have in it right now. I have test pipe, lindser boost controller, fuel regulator, 2 chips (europroducts), and mHKS blow off valve. I want to up grade my turbo but I don't know what else I need to put into my car besides the things i already have in it, so if you can give my any information it will be a great help. The turbos I have been looking at are the Kokeln street turbo($1300) and the Koklen street ball bearing turbo ($1960) which are both on Lindseyracing.com. But again i would like to know if anyone knows which one is more worth it. I would like to know how much lag each one has and how much hp each one can produce? My last question is I need a new clutch but i don't know which one is better for me. I need a good one that can lst because i drive my car hard and i need a reliable clutch. So any information anyone can give me will be a great help and i thank you very much.
Marc
Marc
You might want to try majestic turbo in Texas for turbos. Plus those turbos are not water cooled if iam not mistaken. Do you have a MAF to go with that turbo? You will need a new set of chips with upgraded turbo. PB to control you'e AF ratio. As for the clutch a cup clutch is fine. Stock WG will not hold15 psi boost to red line.
wasn't lister "dmoffit" selling a slightly used (maybe 5k miles) kokeln street turbo a month or so ago? do a search under his user name...may save you some cash. dont forget injectors!
dont know if it ever sold....heres a link to the thread
