I'm sticking to air cooled
Old 10-15-2020 | 03:59 PM
UserA's Avatar
UserA
Coolant appeared to look like I dropped a Mento into a Pepsi. I do not have hard starts after boosting and I haven't done a compression test as of yet and oddly the oil isn't sludgy. Pulling plugs today. If they are wet, then I have my work cut out for me!
Thanks again for all the help.
Old 10-15-2020 | 05:37 PM
Tom M'Guinn's Avatar
Tom M'Guinn
I think the HG is a goner. Mentos and Pepsi rarely lie.
https://members.rennlist.com/tom86951/headgasket.htm
Old 10-15-2020 | 05:57 PM
UserA's Avatar
UserA
I agree Tom, I am going to install a new one using your guide. Thanks for taking the time to make it.
Old 10-18-2020 | 12:37 PM
odurandina's Avatar
odurandina
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Hydro lock will be a highly likely indicator of a HG......
Sticking with the Air Cooled......
God yes. i shoulda bought this cheap SC that was for sale for a song up the street from me
in 2010 Woulda been a nice alt P car driver when the Sledgehammer is getting serviced.
Old 10-18-2020 | 09:54 PM
schip43's Avatar
schip43
Well pressure testing before pulling it apart ... could not hurt! But it sound's most likely it is the head gasket?? As for Air Cooled vs Water Cooled?? Well yeah, if you don't have a water pump, thermostat, radiator and the assorted hoses, then they can't break.
heliolps2 (11-06-2022)
Old 10-18-2020 | 11:35 PM
Humboldtgrin's Avatar
Humboldtgrin
How much boost is the car running? What you describe would indicate head lift. Which is a head gasket failure. But caused by too much boost. Yea I know there’s never enough boost. Or wrong tune, or air pocket in coolant jacket in the cylinder head. Or head bolts not torqued property. Or, or, or.... yep.
Old 10-20-2020 | 11:23 AM
UserA's Avatar
UserA
Stock boost, head lift could possibly be the cause. I pressure tested the system and it held 11psi with no problem.
Old 10-20-2020 | 12:39 PM
Tom M'Guinn
Keep in mind the head gasket sees maybe 100 times that much pressure when the fuel ignites and starts pushing the piston down. If some of that pressure gets past the HG into the cooling system, you spit up coolant. And, if that pressure can't escape the cooling system fast enough, it will push coolant back into the cylinder on intake and exhaust strokes and/or when you turn off the motor.
Quick Reply: I'm sticking to air cooled
