Idle control valve???
87 951 80K Some upgrades done may 2018 Super 48 Spec 3 clutch custom chip Dual-port 3 Bar MBC Solid AFR's Headgasket belts ICV etc.No MAF Stock AFM and Air box. Story short. ha ha, car has not skipped a beat 10k+ since 2018. Runs perfect to shop for 321 Headers and motor mounts. While at the shop post install car heat cycled, on idle only(20+ minutes) several times for stud re-torque, with no problems.Vehicle was not road tested prior to pick-up, dissappointed, but assumed all should be good. Sits overnight inside mech. Started, idle dead solid, driven outside to parking spot on shop lot no problems. Return to shop for pickup car has sat couple of hours popped hood check out the work with mech. very nice. Started runs perfect on idle warm-up rev motor no leaks all good. Upon pulling out from shop almost stalls barely runs drive two blocks return to shop I hope its just a obvious vacuum leak(large) with mech. Opened gas cap Vapor Lock? No change. Start car barely idles when it does, drops way down bumps back-up then stalling Repeat process using throttle to keep running miss fires popping back through airbox. Check plugs wires disconnect afm everything poss., while hot, all good no sucking sounds or hissing mech. sprayed starting fluid to various areas especially ICV no change. Leave the car at shop. Leave to go home, hour later mech. calls says car sat cooled, started, to move it in lot. Car idles perfect, revs no misses, takes for a 20 min. drive doesn't beat it but puts on boost pulls fine. Stop lights, idles perfect. Mech. and I decide to leave it for the weekend to see what it does Monday possible smoke test. I know this will show if vacuum related but if no leaks, thoughts on other possibilities?
Let me first apologize for rambling,
Have a Good Weekend
Ron D.
Have a Good Weekend
Ron D.
This is what I just read: Lorem ipsum dolor sit amet, consectetur adipiscing elit. Proin auctor, erat id faucibus convallis, ex lacus sollicitudin odio, nec congue arcu libero sit amet ante. Donec congue in elit nec vehicula. Sed sit amet efficitur dui, sit amet lobortis ligula. Maecenas eget commodo mi. Ut in lobortis dolor, non sagittis purus. Cras vel fringilla lacus, vitae facilisis sapien. Maecenas sed mollis mi, id malesuada felis. Nullam vitae pulvinar felis. Aenean non sagittis eros. Cras convallis pulvinar nunc eu ultricies. Phasellus pellentesque et tortor ac suscipit. Aliquam eget faucibus quam. Vivamus congue elementum odio, at gravida neque tincidunt ut. Curabitur venenatis dignissim elit eu dapibus. Sed congue felis in metus condimentum, nec condimentum tortor euismod. Ut sed sapien fringilla risus semper rhoncus. In sollicitudin nulla non sem feugiat, eget vulputate nisl viverra. Vivamus vitae nunc ut augue tempor condimentum sit amet eget risus. Nam in diam pellentesque, iaculis diam vitae, finibus arcu. Praesent convallis sapien eget magna faucibus laoreet. Phasellus luctus mollis odio non imperdiet. Quisque vel est neque. Sed bibendum magna non eros eleifend elementum. Lorem ipsum dolor sit amet, consectetur adipiscing elit. Phasellus ullamcorper est id porta posuere. Aliquam euismod elit ligula, sollicitudin vestibulum nisi imperdiet eget. Ut mollis ligula sem, id eleifend neque sagittis sit amet. Etiam dui sem, ultricies sed velit ac, maximus eleifend odio. Nam eget nulla elementum, mollis erat vel, suscipit lorem. Aliquam varius quam lacinia purus venenatis finibus ac ut nulla. Quisque hendrerit malesuada felis, eu finibus tortor condimentum quis. In luctus eros justo, ac malesuada justo auctor ut. Praesent sagittis est sit amet posuere vulputate. Nulla facilisi. Integer volutpat massa sed magna porta, vitae fermentum urna dignissim. Proin placerat libero nec lobortis ultricies. Nullam lorem tortor, imperdiet vitae cursus ut, bibendum vitae quam. Mauris molestie mi ut felis pellentesque fermentum. Donec volutpat velit diam, ut condimentum ipsum tincidunt a. Quisque ultrices lacinia bibendum. Aliquam pharetra mi sagittis lorem fringilla molestie. Curabitur consequat augue id justo commodo bibendum. Nam est lectus, efficitur sed gravida et, aliquet vel lorem. Morbi mollis tincidunt nibh, eu cursus turpis blandit mattis. Orci varius natoque penatibus et magnis dis parturient montes, nascetur ridiculus mus. Nullam eget ipsum nunc. In consectetur hendrerit urna et laoreet. Nullam efficitur lacinia convallis. Mauris vel mollis tortor. Maecenas bibendum elit id varius semper. Curabitur aliquam magna est, at pretium dui feugiat viverra. Proin ornare ligula elit, sed suscipit purus interdum a. Proin nulla metus, venenatis vitae lectus at, tincidunt tincidunt elit. Morbi mattis risus lacus, sed auctor lectus auctor eu. Nam ut pretium mauris, et cursus sem. Ut posuere lorem est. Suspendisse vitae ex urna. Mauris placerat suscipit elit. Vivamus id augue fringilla metus porta eleifend. Sed tempus ligula vitae massa ullamcorper pretium. Class aptent taciti sociosqu ad litora torquent per conubia nostra, per inceptos himenaeos. Maecenas pretium mattis leo sit amet imperdiet. Proin dictum velit vitae ultricies venenatis. Praesent in dignissim orci. Maecenas mattis nisl eget urna dictum, ac tempus enim rhoncus. Mauris lacinia felis orci, id fringilla neque venenatis in. Quisque et enim interdum, lacinia sapien sit amet, iaculis sem. Aliquam eu tincidunt ipsum. Lorem ipsum dolor sit amet, consectetur adipiscing elit. Cras laoreet nunc a ornare viverra. Pellentesque bibendum, urna sed vulputate facilisis, dolor nibh vestibulum augue, et facilisis enim ipsum malesuada quam. Donec quis semper diam. Fusce aliquet odio felis, et tincidunt felis maximus eget. Vestibulum varius nec mauris a accumsan. Praesent sed posuere augue, non elementum orci.
What kind of lift was the vehicle placed on? I've seen some of our cars scrape on four post alignment style lift s which end up pinching the fuel return or send or both lines.
