Do I have a blown headgasket?
Disappearing coolant redux: well, it appears this was a false alarm. I've been driving the car more frequently over the last couple of days, and the coolant level hasn't dropped.
In fact, two days ago I went grocery shopping, and when I arrived at the store, I checked the coolant to see that it was much lower! This was after driving for 4 miles, with a semi-warmed up engine. So the coolant level should actually have been higher than when cold. So that looked bad , but after I had driven the car home and checked the level again, the level was okay again!
So it seems to me (as Tom suggested) that maybe there is still a small air pocket in the system. At least I don't seem to lose coolant anymore!
i might suggest the block testing kit from napa - about 40 bucks. very easy test to see if there are exhaust gasses in your coolant. might put this whole thing behind you and give you peace of mind.
