In Search of Rogue Data Logger
Old 12-04-2019, 06:01 PM
kev951
kev951's Avatar
Default In Search of Rogue Data Logger
Anyone have a ROGUE Tuning DATA logger they are no longer using or would like to sell ? I have an older M-TUNE (plastic MAF) kit with ROGUE ECU and Ostrich . Would like to have the ability to log so that future tuning will go smoothly. Heavily modded 2.5 motor with Garret 3076r (GT30r BB turbo) Thanks in advance!
Mods:
M-Tune (plastic maf tube) Map sensor, with flow matched NEW DECA fuel injectors, Rogue ECU with Ostrich
Adjustable cam gear
Kevlar Timing belt
Tial 46mm gate (atmosphere dump)
Turbo smart recirc valve (with atmosphere dump option)
Garret gt30r turbo
Lindsey Log intake manifold
SFR coolant tank
Updated lindsey fuel rail , 044 pump, and teflon lined SS fuel lines for the entire car
4" progressive turbo back
321 ss headers and exhaust,
O-ringed head, ported, and rebuilt head
Racewear head and main studs, Arp rod bolts
Teflon crank scraper + windage tray combo
Knife edged crank, nitrided , cross drilled
Baffled oil pan + pickup tube support and and ring
Wossner pistons and rings and shot peened factory rods,
Complete rotating assembly balanced + balance shaft delete
Calicoo coated rod bearings + new main bearing set
large oil cooler
stage 2 intercooler
large wizard radiator
Nology coil with custom plug wires
AVCR boost controller
Wideband 02 in downpipe, New factory 02 in original location
Spec stage 3+ clutch and pp (fully balanced)
ALL NEW FASTENERS, ZINC, HEATSHEILDING (factory)
Turbo S transaxle + Cooler
New Torque tube , axles, etc. + Extensive suspension upgrades
Way more mods I can list that will likely never end... I really want to finish this 10 year ongoing project.
Old 12-04-2019, 07:31 PM
refresh951
refresh951's Avatar
https://www.lindseyracing.com/LR/Parts/DMELOG.html
Old 12-05-2019, 04:04 PM
kev951
kev951's Avatar
Per Lindsey's website: this only works with the newer M-tune kit incorporating the METAL MAF not the plastic. Not sure what the differences are 🤔🤔
Old 12-05-2019, 06:31 PM
refresh951
refresh951's Avatar
I cannot think of why it matters, I will ask Josh and post back here.
Old 12-05-2019, 08:48 PM
kev951
kev951's Avatar
Old 12-05-2019, 10:29 PM
gpr8er
gpr8er's Avatar
just curious but with all the mods/upgrades why didn't you go to a 3L motor?
Old 12-06-2019, 05:51 PM
Mike Goebel
Mike Goebel's Avatar
How about a logger for the A-Tune?
Mike G.
Old 12-06-2019, 10:26 PM
fejjj
fejjj's Avatar
Kev,
I have the logger and it works fine with the older Mtune and Rogue ECU.
Old 12-07-2019, 03:48 PM
kev951
kev951's Avatar
Thanks @fejjj ,
So do I have the green light to order a new one from Lindsey? Are you running your wideband O2 signal into the logger as well
Old 12-08-2019, 10:17 PM
fejjj
fejjj's Avatar
I am not running my wideband signal into the logger but it is capable.
kev951 (12-09-2019)
Old 12-16-2019, 02:09 AM
victor25
victor25's Avatar
Ordered the LR DME logger. It took a while, had to try a few version, but I have both up and running on Tunerpro RT version 5.00.8202.
Problem is, I have an NA engine and computer. LR says the it's for the M-tune and the NA-tune, but they only have definition files for the M-tune.
Tried the Rogue DME logger files, but they wont communicate with the LR logger.
Any ideas?
Quick Reply: In Search of Rogue Data Logger
