Custom CNC fitting to recirculate oil back into oil pan from catch can....
Old 02-25-2004, 10:26 PM
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Default Custom CNC fitting to recirculate oil back into oil pan from catch can....
Here it is...
Up until now I was using a modifed oil level sender (drilled and tapped)... but it doesn't work well and leaks a little since you can't thread in a NPT fitting very well because the "meat" of the flange is offset too far.
That is until now...
Here's the new fitting. This will allow a 3/8" NPT fitting on the outside AND inside, thus allowing a 90 to be used in the oil pan to ensure that the drain opening is never above the oil level.
Just in today...
Old 02-25-2004, 11:08 PM
Matt H
Matt H's Avatar
Anyone know what the p/n for the triangular gasket is? I could really use one!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 02-26-2004, 12:53 AM
cpt_koolbeenz
cpt_koolbeenz's Avatar
944 101 233 01 - old P/N
944 101 233 02 - new P/N
Old 02-26-2004, 07:59 AM
keith
keith's Avatar
Tony - how much for those jobbers?
Old 02-26-2004, 08:58 AM
B951S
B951S's Avatar
Very nice...I was thinking of tapping the big turbo return banjo bolt. How much is that machined unit?
Old 02-26-2004, 11:39 AM
TonyG
TonyG's Avatar
keith & B951S,
Calll Lorenzo at L&M Machine. 661.257.4840 Tell him Tony the Porsche guy sent you. He did the program for the cnc, so making more is a breeze.
TonyG
Old 02-26-2004, 12:07 PM
Ahmet
Ahmet's Avatar
Nice piece, so did you give up the oil level sender?
PS: I've never used that gasket, use loctite 574 (that is porsche glue isn't it, the orange stuff) instead. No leaks...
Ahmet
Old 02-26-2004, 01:41 PM
Alan C.
Alan C.'s Avatar
Received 1,061 Likes on 547 Posts
Or you could try Hylomar. That's what I have on mine and it has worked for 2 years.
Nice piece Tony, I just cut a piece of 1/2" plate when I did mine. Ugly but effective.
Old 02-26-2004, 03:10 PM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Copper tubing? Tony – I’m surprised, you usually do better than that!
Seriously – the copper tubing will work harden from vibration/heat and eventually crack.
Chris White
Old 02-26-2004, 03:32 PM
TonyG
TonyG's Avatar
Chris White
I've been using copper tubing for years and years on many cars and have never once had a problem.
Not saying that I couldn't happen, but I've never witnessed a problem.
I've used it on for 20 years on oil pressure gauges. Not once, on any of the cars, has there ever been a problem. Thus my decision to use it for the oil catch can.
TonyG
Old 02-26-2004, 09:32 PM
keith
keith's Avatar
Tony - can you post pics of the entire vent/catchcan/return system?
Old 02-26-2004, 09:47 PM
NZ951
NZ951's Avatar
Oil pressure or level sender??? I did not think we had level. Surely its the pressure on the botton left side of the engine looking at it...
Old 02-26-2004, 10:23 PM
Sam Lin
Sam Lin's Avatar
Level.
Sam
Old 02-26-2004, 10:38 PM
NZ951
NZ951's Avatar
Where on gods green porsche does the level sender report to?
Old 02-26-2004, 10:40 PM
NZ951
NZ951's Avatar
I am 50% through making one that was going to drain via a valve. If I could tap it into the oil level sender, which I always monitor anyway, that would be great! I did not want to give up my pressure gauge. Little help T?
Quick Reply: Custom CNC fitting to recirculate oil back into oil pan from catch can....
