Who sells EGT sensors?
I want to mount an egt sensor in the #4 header.
Who sells egt-sensors (and wire/display)?
How long will this sensor last if you drive with it constantly?
How do you install the sensor, do you just bore a hole and weld
a nut on the header?
Thanks.
Thanks.
I have this sensor and gauge from autometer. I had Lindsey racing weld the 1/8 NPT bung on the #4 while it was there. If I was to do it again, I would weld it pointing straight towards the firewall at 9 oclock. I put mine at like 10:30 to avoid the water pipe, but was very difficult to get to.
