radiator for racing
Hi,
Has anyone had any experiences with the plastic endtanks on the stock rad failing in a road race environment? If so, I have not seen many options for aftermarket rads, what are some good alternatives? Also, with a properly ducted stock rad and large oil cooler in place, will overheating be a concern?
Thanks,
Andrew Wojteczko
Thanks,
Andrew Wojteczko
So far after a couple seasons on the track, I've found that the stock radiator works just fine; except for when I crashed at Laguna and had to replace it. One day, it was 46-C degrees at Willow Springs with a a track temp of 57-C degrees. During a 30-minute full-throttle sessions, the temperature never got above 3/5th on the gauge. After I pulled off the track and slowed down, the temp. would creep up a little to the 2/3rd mark. But after slowly driving up to the Balcony and coasting down, it was back down at the 1/3rd mark like normal by the time I got back to the pit.
Oil-temperature is a concern that I'll attack next. The hot oil dropped pressure from 5-bar on the gauge down to 3.5-bar while under full-throttle. A larger oil-cooler should remedy that.
Nope stock water-temp gauge. But I am adding a oil-temp, oil-pressure and fuel-pressure to have some more diagnostics on board. So far the has not been a problem. Some of the guys with dedicated race cars remove the thermostat to get a little more flow. Although I suspect the main limiting factor in the cooling system is the surface area of the radiator. That'll determine how much heat can be shed per second.
